Localization and Globalisation
we are using ax 2009 how to find the wether batabase is localization and globalisation in database level?
It is the configuration which decides the localization.
So you need to check the configuration for that - but not the at the data base level.
Hi Kranthi,
configuration means system configuration or anything else
would you please tell me the what is the minimum configurations of localization and globalisation?
In ax look into Administration → System → configuration → Country or Regional specific features.(for knowing the which countries local features are being enabled).(Note - don’t apply any unwanted changes - it may drop some unwanted fields,tables from the database)
