Hi Pioneers,
While going through the table property, I came across the “ListPageRef” property in tables in Ax 2012. Kindly help me in understanding this. that what is the use and when it can be used ?
Hi Pioneers,
Specifies a display menu item that points to a form that can show a list of this record type.
http://msdn.microsoft.com/en-us/library/dicttable.listpageref.aspx
for more information about table properties you can refer to http://msdn.microsoft.com/en-us/library/aa871620.aspx
Thanks, On going through the articles, it shows “Specifies a display menu item that points to a form that can show a list of this record type.”
Please help me in understanding " that do this property only here for format type (i.e, List, detail)" or it is for “Go to main table” property. For experimenting, I changed the “ListPageRef” property of “CustTable” to various forms…but I didnot encountered any change pattern or records. Then what does it mean ?
Please reply
please check from the menu item and please make sure that the menu item points a form not a report or ssrs report please check and let us know…
I checked by passing CustAgingStatistics , which is a form. But I didnot find any change in format. Kindly send me a screenshot regarding working of ListPageRef.
Somebody please reply.
After going through the definition in blog, “**Specifies a display menu item that points to a form that can show a list of this record type.”, what the "**list of this record type." meant ?
Hi, Somebody please reply
Please reply.
