Hi Friends, Problem: I have a Grid that is assigned DataSource-1 and there is a column in grid that is assigned to datasource-2. between these datasources there is a join , what kind of Linktype should be assigned that shows data from datasource-2 either there is data or not? thanks
Hi, Massoud Try setting outer Join Also look at the property fetchMode
