I’m using a tempDB (called tempDB here) as a datasource on a form to keep a running total of some ledger lines.
In testing, I created an init method that called a populateData method on the form object and the database populates successfully: tempDB.linkPhysicalTableInstance(element.populateData());
However, I am interested in editing and adding records to this datasource on a display method of another datasource. The code compiles, but when I loop through tempDB_DS only the initial records exists and are unchanged.
Can you run the linkPhysicalTableInstance method from outside of init?
