I need your help and expertise. I cant find where i can link and get the information of the shortcut dimension code that is not declare as one of the global dimension.
How can i show it to the report? because its not presently on the general journal line. i tried to edit the general journal line and declare the other existing shortcut dimension code in C/AL Global code? am I right on the process? but the other problem is our license doesn’t have the right to add that kind of code on global code. what i supposed to do?
actually its good for all the report… so for n ow im just trying to make an output in one report like the Purchase Order but unfortunately, only the global dimensions is the field that been declare and when i used the same code but change it to for sample: dim1=shortcut dimension 1 code, dim2 for shortcut dimension 2 code and for dim3 and dim4 is the shortcut dimension 3 and 4 code… but still the output will appear as the same of dim1 and dim2. In short, i cant used the dimension value to declare and make a value for dim3 en 4.
so can u kindly help me… im already exhausted where i can get the input information for shortcut3 en 4 and be an output in my report.
i already used the gen. journal line in my report and still it only comes out with shortcut dimension 1 and 2. sadly, the other shortcut dimension 3 and 4 code are not presently on the list. but if you will look up on the table its was there…
Do you mean you create a flowfield for these dimension in Gen Journal Line? If so, go to your DataItem properties → CalcFields → define your dimensions flowfield here.
