Link from Navison to a different application
I pretend create a link on Navision 6 SP1 to a different application.
The idea is to help user on his work Instead of close nav to work with another SW Application, He call’s that SW from Navision.
How can I do That?
Hi Luana,
You can do that using the HYPERLINK function.
Do you want to open that application from Navision on click of button ?
Yes
Can you give me one navision example? I have never use that function on Nav
There are plenty of examples, just search for Dynamics NAV and Hyperlink, or you can check out the tag page:
http://dynamicsuser.net/forums/tags/Hyperlink/default.aspx
Erik
Using the HYPERLINK function, I inseert this on a new form :
Form - OnOpenForm()
HYPERLINK(‘file://G:\WCLINICAS\Wintouch.Healthcare.App.exe’);
But the application is not exeuted.
Try this: HYPERLINK(‘G:\WCLINICAS\Wintouch.Healthcare.App.exe’);
You have to Use Shell Command to execute EXE
Check this link
http://msdn.microsoft.com/en-us/library/dd355282.aspx
In fact SHELL is better here. Hyperlink is used to open a specific HYPERLINK to a document or a URL. It will not open your application.
The problem is that SHELL is not supported by RoleTailored Client (= any future versions of NAV).
Hi Erik .
I tried to make link with macro excel 2010 :
I make a share folder in server. And I want to execute that folder file from Navision client PC.
HYPERLINK (’ \Server|Macro\ABC.xlsm’ ); but it is NOT WORK. the warning message : "Hyperlink failed to find the target …
if I Run directly from server it is work fine.
do you have other solution for this hyperlink ( from client PC to NAv server ) ?
thks
Alfian 98 .
