link between the Purch. Cr. Memo Line and Purchase Linet ables
What is the data item link between the Purch. Cr. Memo Line and Purchase Linet ables?
Welcome To DUG
Can you tell me your requirement.
regards
In Purchase Cr Memo you will see a field called (No.). If you go to Purchalse line table you will also find this Field which will link both lines together based on the No.
Hi Jaweher,
Check out this question. It’s basically the same question that you ask.
[View:~/nav/f/106/t/89478:320:50]
