I am assigning roles to users to limit each user’s access in NAV. I noticed that the “P&P-Q/O/I/R/C, POST” role for posting purchase orders contains the job ledger entries and G/L entries table by default. I also noticed that these tables are required for a user to be able to post purchase invoices. I am confused because access to these two tables gives users access to view the chart of accounts, GL ledger entries, and job ledger entries. Is there a way to allow a user to post purchase invoices but not be able to view the G/L entries, and job ledger entries?
Typically, you control a user’s access to data by controlling the forms, pages and reports through which they would view that data. Instead of trying to limit their access to the underlying tables, start looking at the roles that grant permissions to the specific objects that allow them to view that data.
Hope that helps.
We took the approach of permissions, you will be working on it for the next 10 years all of a sudden a new table is required things are changing in the business.
We have found giving higher permissions is easier and then cutting the role center so they cant get anywhere they shouldn’t has been the easiest route, of course this means disabling customization of the role center which someone companies wouldn’t like but it does make life easier in support as you know each department has a set layout and once you remove the departments tab from there menu it removes all the search as well.
Regards
Lee
IS this what you are looking for ?
