Limiting Multiple Instances...
I have users that open multiple instances of Navision for no reason and therefore reduce the number of available licenses. Is there some way to limit certian users so that they can have only one instance of Navision open at any given time?
Do a search on this topic. You will find plenty of information. One big question in the approach to your problem would be if you are running the Navision or SQL database.
Some of our client using a software to auto close the Navision session running on SQL. Check this website for the software. http://www.autocloseidle.com Naveen Jain
