Hi Experts,
I originally bought Starter Pack with 5 additional user licenses for Company A. I now have Company B and planning to setup new database and new company because they are of different industry/entity.
Do I have to buy Starter Pack license if I will set up new database and new company on the same SQL Server? Or additional user will be enough?
Please advise.
Thanks!
Is Additional company is under the same group company ?
If yes then we can add more license and can use the same license for company B
If not then you have to buy separate license.
Hi Amol,
Yes it is under the same group of company. Company B will set up on separate database and on the same server.
No, 1 database with 2 companies. Your license only allows you 1 database. If you want a second database, you need a second license.
For Separate database you need to have different license.
