License needed to lookup historical data?
We do have a customer (6 employees) who want to stop using Axapta 3.0 and start using a different application.
They will not transfer any historical data from Axapta to the new system, but they will need to make a lookup in the Axapta system from time to time, at least for one year.
The company that have sold them Axapta tells them that they need to buy one license, which is quite expensive – otherwise they will not be able to lookup historical data.
As stated above this is a small company and they find this almost too expensive to pay just to be able to lookup historical data.
Does anyone know what happens if the license expire?
Does it really prevent access to the system or will it just deny registering new entries?
Is it anyone that have any cheaper solution for this customer?
I think you should speak to Microsoft.
Very interesting question. As being from the NAV side, then I’m too a bit curious if this is how thngs are done Axapta world?
In NAV if you at one point have purchased a license, then you can continue to use this license, for as long as you want. Must one pay just to continue to use AX?
Doing an implementation like this is, at least in the NAV industry, very common. You don’t want to deal with upgrading historical entries, as the customer really doesn’t need them for too much, so we keep the old system online in a read-only mode, for 1-2 years after the conversion. I have NEVER heard about any customer, who had to buy a new license just for that.
So although the right answer might be “speak to Microsoft”, then I’m sure Reidar and many others would love to hear if this is really true. Is that the way it works in AX? [:)]
I also thought that the license doesn’t expire, but if Reidar claims it’s not the case, I can’t dispute it. Unfortunately I don’t remember details of Axapta 3.0 licensing. It was almost ten years ago…
Thank you everyone for good and quick replies!
The company that has sold them Axapta claim that they do need to buy a license, but I will ask Microsoft directly.
You said that you “have a customer who want to stop using Axapta 3.0”, therefore they already have licenses, don’t they? Can you please explain why can’t continue using them?
The company that have sold them Axapta told them that to be able to lookup historical data in 2016 they have to renew their license. The renewal is very expensive.
So; yes they do have an active license now, but it will expire at some point and according to their supplier Axapta will not be accessible after the expiration. Therefore, they must pay for the renewal - even if the goal is only to take a look at historical data.
If the customer has a perpetual license, I have almost sure, that you don’t need to renew the maintenance to access historical data. From time to time I found customers complaining about expiring licenses (always in Dynamics NAV world). That happened when the previous partner left is license installed on the server instead of customer license. You can open Axapta and confirm the expiration date in license.
As Martin mentioned, Microsoft can help you on that matter.
Licensing in AX and NAV are similar and comparing to other ERP vendors licensing model is quite simple.
Hi Reidar,
Usually service plan is required in order to be eligible to receive product updates, patches, etc.
If you check the license file in Axapta 3.0, that should provide some clue. Usually customer license files will not have an expiry date. Only trial license files will have specific expiry dates.
So as long as your customer’s license does not have expiry date, then AX installation should be fine. However it is good to validate this from Microsoft.
Update:
As advised, I asked Microsoft regarding this case. The answer follows below.
"The customer can continue to use his license to lookup onto his historical without having to purchase a new license.
The right to use the software is perpetual, this means that customer can continue to use the software as long as he want.
See Microsoft software license terms Microsoft Dynamics AX 3.x, AX 4.x, AX 2009 (p, 5):
Your rights to use the software are perpetual but may be revoked if you or your affiliates do not comply with the terms of this agreement. Rights to access the server software do not give you any right to implement Microsoft patents or other Microsoft intellectual property in software or devices that access the server."
Thanks for your update, this is important for other members, I have marked your answer as solved.
