LedgerRowDefDesigner Form
Can anyone tell me why this code is used in the executeQuery() of LedgerRowDef datasource.
query = new Query();
qbDataSource = query.addDataSource(tablenum(LedgerRowDef));
dimensionTopicsPrioritizer = DimensionTopicsPrioritizer::newDimensionSetId(lrDef.MainFocus);
dimensionTopic = dimensionTopicsPrioritizer.lastDimensionTopic();
maxLedgerRowDefPriority = dimensionTopicsPrioritizer.dimensionTopic2Priority(dimensionTopic);
ledgerRowDefLineBuffer.RowDefinition = lrDef.RowDefinition;
while select ledgerRowDefBuffer
if((ledgerRowDefSetup.Hierarchy && (!ledgerRowDefBuffer.Hierarchy || !ledgerRowDefBuffer.isUpdatedAndApproved())) ||
(!ledgerRowDefSetup.Hierarchy &&
ledgerRowDefBuffer.Hierarchy &&
continue;
for(i = 1; i <= maxLedgerRowDefPriority; i++)
ledgerRowDefLineBuffer.Priority = i;
if(LedgerRowDefLine::checkRefRowStructure(ledgerRowDefLineBuffer, ledgerRowDefBuffer))
qbDataSource.addRange(fieldnum(LedgerRowDef, RowDefinition)).value(queryValue(ledgerRowDefBuffer.RowDefinition));
foundAvailableStructure = true;
if(!foundAvailableStructure)
qbDataSource.addRange(fieldnum(LedgerRowDef, RowDefinition)).value(SysQuery::valueEmptyString());
this.query(query);
Actually I am opening the structure designer for an hierarchy and I am getting an error like,
SQL error description: [Microsoft][ODBC SQL Server Driver][SQL Server]Some part of your SQL statement is nested too deeply. Rewrite the query or break it up into smaller queries.
The reason for this error is the above code. I can see it is taking into account all the hierarchies belong to the set and adding them as range in the italicized and underlined code . But I couldn’t find the reason.
Even if I comment this code, I could not see any difference in the process.
Please help me find out the use of this code.
Many Thanks,
Bharath C G.
