LedgerDimension from individual DefaultDimension
Hi everybody,
have a problem setting up LedgerDimension from an individual dimension of Cust’s DefaultDimension.
I’ll try to explain better by posting my code
CustTable   custTable;
int         i;
DimensionValue         dimValue;
LedgerDimensionAccount  ledgerAccount;
DimensionAttributeValueSetStorage   dimStorage;
custTable = custTable::find(#AccountNum#);
dimStorage = DimensionAttributeValueSetStorage::find(custTable.DefaultDimension);
for (i= 1 ; i<= dimStorage.elements() ; i++)
    if(DimensionAttribute::find(dimStorage.getAttributeByIndex(i)).Name == #SearchedDimension#)
        dimValue = dimStorage.getDisplayValueByIndex(i);
        break;
ledgerAccount = DimensionDefaultingService::ServiceCreateLedgerDimension(_ledgerDimensionOrig, #NewDefaultDimension#);
What I am trying to achieve is to merge my _ledgerDimensionOrig with the value of the found individual dimension (dimValue). But I am stuck on how to create the #NewDefaultDimension# starting from that individual dimension.
Hope I explained mysef,
Thanks for any replies!
Joshua
at the end I found out the solution.
I use this function below that returns the DimensionDefault created from just my individual extracted _dimValue from previous code.
private DimensionDefault createDimensionDefault(str _dimValue)
    DimensionAttributeValueSetStorage   valueSetStorage = new DimensionAttributeValueSetStorage();
    DimensionDefault                    result;
    int                     i;
    DimensionAttribute      dimensionAttribute;
    DimensionAttributeValue dimensionAttributeValue;
    container               conAttr = ["DIMVALUE"];
    container               conValue = [_dimValue];
    str                     dimValue;
    for (i = 1; i <= conLen(conAttr); i++)
        dimensionAttribute = dimensionAttribute::findByName(conPeek(conAttr,i));
        if (dimensionAttribute.RecId == 0)
            continue;
        dimValue = conPeek(conValue,i);
        if (dimValue != "")
            dimensionAttributeValue =
                    dimensionAttributeValue::findByDimensionAttributeAndValue(dimensionAttribute,dimValue,false,true);
            valueSetStorage.addItem(dimensionAttributeValue);
    return valueSetStorage.save();
So now I just changed upper post code into
ledgerAccount = DimensionDefaultingService::ServiceCreateLedgerDimension(_ledgerDimensionOrig, this.createDimensionDefault(dimValue));
Hope will help someone with same issue.
Have a great day!
