Hello all,
How to read the value from cell of a excel sheet with all leading values in columns.
using following code to read the column value
case COMVariantType::VT_R8 :
num2str(com.double());
Break;
If my input is 00010 . it is giving me result as 10 only.
Kindly Suggest
You read a “double” value and that’s 10. There is nothing like a number 00010 distinct to 10. Leading zeros can be added, of course, when formatting a number to text. That’s exactly what you should do in AX (you can use num2str0() instead of num2str()).
Another approach would be to base the whole solution not on a numeric value, but on a text created by applying a format to the number in Excel.
