Lead Time Calculation
We are running Navision Financials 2.6B and we want to use the Lead Time Calculation, except it doesn’t calculate when we do a Purchase Order. However, if I go see Navision Help, it tells that it supposed to calculate. Is it suppose to work in my current version ?
Hi Sebastian, the lead time will be calculated only, when you go to the requestion worksheet, than functions - calculate plan. When you execute the function ‘make orders’ the expected receipt date will be copied into the purchase lines. Whe you enter an order directly, the expected date from the header will be copied into each line. Michael
Hi, I just want to add that you do not have to run functions - calculate plan. You can manually create lines in the Requisition worksheet. System will calculate Expected Receipt Date based on Order Date and Lead Time. Valentin Gvozdev Andel Jewelry Inc.
Hi Sebastian, if you don’t have NF with Manufacturing, you have to execute the function ‘reorder inventory item’, but the procedure is the same. Valentin, I have tried it manually, you will get the date, but no quantity. Michael
