LCD display - Navision other resolution?
Hi We just got nice new 17" LCD monitors [:)]. The recommended resolution is 1280x1024. This is fine for all programs - except Navision. In all other programs I can adjust the menu font size. Only the Navision menus and the designer are still in this small Tahoma font [:(!]. Does somebody know how I can solve this problem without changing the resolution back to 1024x768 for all programs? Is there a way to show only Navision in a smaller resolution? Changing the menu font in Navision is not a solution because there a several employees with the old screens. Any help will be appreciated. bye André
Hi, Have you tried to change the display screen setting (desktop properties).
Hi
quote:
YEP. As I wrote the settings I made are OK for all other programs. I changed the menu font to Arial 12 and so on … No problem here. The Navision menu bar is OK also. But the ‘Build In’- menu font in Navison causes problems. I’m afraid I need glasses if I longer work with this small font [xx(]. bye André
Hi Andre This has come up before, at least once. I know the answer is No, but this does not mean it is not possible. Have a look at this thread it mentions the read only stx file [xx(] http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=3596&SearchTerms=font+size Have fun [:D]
Heres another more in-depth discussion with reference to another link: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=3778&SearchTerms=font+size I see you contributed twice - are you losing your memory [:D] or just praying someone has thought of away around it!!!
Hi I think I just found a small work-around. First I set the View on Big Fonts (125% of normal). Then I adjusted all my desktop fonts (e.g. menu) back to Arial 10. I think now I can live with the font size within the Navision forms. Thank you for your help. bye André
quote:
Ohh. You are right. I have posted it on June 7th 2002. It is a long time ago [8D]. But no matter I found the same solution ‘Large Fonts’ again [:D]. bye André
