I have a table with 3 records with the same Order no. and each one with a version nº, how can I get the record that have the last version?
Regards
Regards
you can sort it by version no and by using FINDLAST
In my report I have only one data Item = Table 5109.
I Created a New Key (No., Version No.)
Order my DataItem by this key and order ascending
On My
Purchase Header Archive - OnAfterGetRecord()
PurchaseHeaderArchive.SETCURRENTKEY(“No.”,“Version No.”);
IF PurchaseHeaderArchive.FINDLAST THEN
PurchaseHeaderArchive.GET(“No.”,"Version No.);
But this returns on error
What is the need of above?
I need all recods from table 5109 with the last version of each Order No.
Above will give you only one record, because GET works on primary key.
To get all records from 5109 with the last version only, what do you suggest?
Group 5109 with No. and in Group Footer use FindLast as above…
I think what they are saying is your code already finds the last record now what do you want to do with it?
…Then What?
txtLastVerion := “Version No.”;
Lose This>>PurchaseHeaderArchive.GET(“No.”,"Version No.);
Like this IF PurchaseHeaderArchive.FINDLAST THEN
I get in my report all records for the same Purchase Order no., with all versions :(, and I need only the most recently version = last version
Did you try this?
I hope it will show only last version per Purchase Order no,.
Hy
I tried this
IF “Purchase Header Archive”.FINDLAST THEN;
Valor := “Purchase Header Archive”.Amount;
and only one record appears in my report, and value variable = 0
Hello
JQPL allows one to get the MAX value of a field, e.g. “select max(o.id) from item o”. Although it does not return an item object, but the return max value can be used to retrieve the item.
JohnMiller
Hello
JohnMiller
As you said, you wull get only one recoed per Document No.
and also user
“Purchase Header Archive”.CALCFIELD(Amount);
before
as Amount is a FlowField
