We’re currently implementing a client that plans to uses landed cost built in 3.10a US. However, if they receive the vendor freight invoices 1 or 2 months later, their inventory value will be grossly undervalued in between those periods. I dug into Navision and couldn’t find any built in feature that will allow Navision to calculate the expected final cost of the item. Is there a easy way of handling this?
to post cost after the regular invoice use the function of item charge assignment. best regards, tiger
quote:
Originally posted by achowtc: We’re currently implementing a client that plans to uses landed cost built in 3.10a US. However, if they receive the vendor freight invoices 1 or 2 months later, their inventory value will be grossly undervalued in between those periods. I dug into Navision and couldn’t find any built in feature that will allow Navision to calculate the expected final cost of the item. Is there a easy way of handling this?
Thanks for the reply. However, is there a easy to post expected landed cost before you actually receive the freight bill?
There is no function which will handle your problem in navision attain standard. but you can customize the application, some few code lines should be sufficient. best regards, tiger
quote:
Originally posted by achowtc: Thanks for the reply. However, is there a easy to post expected landed cost before you actually receive the freight bill?
