Lable Id
Hi
only showing the labeled in all the module name, from name and everywhere where in standrd ax used label id it showing only the label id instead of the its original charter attached with it. Please help me to solve this problem its very argent.i will be very thankful to you
Thanks&&Regards
Bijesh Kumar Singh
The ’ .ald ’ is the file which maintains the labels information of AX. Check is it there r not in ur configurations
There could be many reasons for this issue.
More often, users set language field (check under Tools > Options > General tab) incorrectly. Check whether you are licensed for this language.
Other reason could be the system build might be incorrect. Check whether you have the language files (.ald) under application directory.
Check the labeling setup under Development tools.
Also check .ald root in your application folder of dynamics ax.
Geetika
