I’ve successfully installed and configured SSRS to develop reports in AX2012. I made some modifications to SalesInvoice, deployed it and the modifications work. However, when I run the report from AX2012 the labels show as Labels!@SYS13864. But when I open the report in Visual Studio in design mode and select “Preview”, the labels do show up! I’ve restarted the AOS several times and did a succesful full CIL compile.
I finally found the reason for this. As it turns out, labels are not resolved at run time (which I find confusing, but hey…). To make the labels appear, language-specific versions of a report have to bedeployed to the report server. How that’s done is explained here: http://technet.microsoft.com/en-us/library/hh496446.aspx
The SSRS Service Account password could be invalid.
From the Start menu, point to All Programs, click the SQL Server folder, click the Configuration Toolsfolder, and then click Reporting Services Configuration Manager.
In Reporting Services Configuration Manager click Connect and then click Service Account.
Click the ServerName/MSSQLSERVER and then click Stop. Then click Start to restart the server. Always check with the SQL administrator and make sure no other users are connected to the server before you restart the server.
