hi all
i sucessfully installed ax2012
i just ran standard chart of accounts report which is available by default in ax2012,am able to see the records but the label files r missing it shows the id values like Labels@sys 4578 etc
anyone pls help me… thanx in advance
HI Arun ,
Just restart the Dynamcis AX services . It is for re-indexing the .ali files…
Still you are facing the same problem, check label data once…
-thanks
jagaddish
hi jagadish,
thanx for ur reply,
i restarted my services, after tat also same status only
is there anyway to copy a label files ???
or any other way to solve this???
hi Chaitanya
i tried your solution its not worked
Hi Arun,
Please check the license file, and make sure that license file is correctly synchronized with labels.
hi Vishal,
i re imported the license file its synchronized correctly…
only for ssrs reports only its showing label id values,
not for any other menus
HI Arun,
try this ,
In ssrs report designer , properties window , select the template ,–>with fields & labels…
