Kit Processing in NAV5
Hi all!
I want to create a new kit using bom journal but this I am not able to put select a bin code inside my location ABC . Why? this is the message " Directed put away and pick" must be NO in location ABC.
Does it mean that using Kit with WMS and ADCS is not working ?
Thanks for clarifications
Not at all. If you are going to use bins, then you must have Directed Put Away/Pick = Yes on the location ABC. That’s standard NAV.
" to put select a bin code inside my location ABC "
you mean you cannot go to location card abc and fill inbound bin and outbound bin.??
