Is there any easy to achieve possibility to - get a list of every key - know by fieldno if this field is part of the primary key, - modify Property keygroup through C/side? “Oh no, not again” D. Adams
What you could do is use Impulse Workbench to import the your objects as text file into the Workbench specific table then write some Navision reports to pull out the desired data off the workbench table There about 7 tables or so, Getting the list of every keys is straight forward and for the rest I cannot remember, it’s been a while since I’ve worked on that and I do not have a workbench handy … tarek_demiati@ureach.com
