Key board shortcuts in Navision.
Hi all Shall anybody have the list of all possible short cut keys in Navision ? I am using some short cuts key like F3 for inserting new row,Ctrl+f7 for filttering,Ctrl + f2 to get designer etc. But I don’t have the full list. If somebody can publish the list in this fourm,that may be usful to others also. Regards Joseph Mathew
Joseph - If you are using Financials, simply press alt-F1. You will get a display showing you the keys available to you. Rick I think, therefore you’re not… ------------------------------- Rick Acton High-Tech Consulting Services 301-662-0732
Hi Rick Thank you for your reply. I knew that ALT+F1 will show us the possible shortcut keys. But I have tried this always from main screen. Then I can’t see the all keys. Today I tried this in different screens like in dataentry, report designer,form designer. Then it shows the possible keys can be used for that particular screens . This solve my problem. Regards. Joseph Mathew Edited by - joseph_mathew on 2001 May 22 10:25:44
