Journal says 4 lines, but no lines in detail !!
Hi everybody!
Has anyone encounter a problem with journals that says it has a number of lines, but when going to line details, there are no lines there or less than the journal says? This happen a particular day, 20 journals all of them within the same day.
I’ve looked into InventJournalTable (the journal header exist), InventJournalTrans (no records for that journal) and InventTrans (no records for that journal). Anywhere else I should look to? Any recomendations, suggestions, experiences??
Many thanks!
Héctor
Only seen a similar issue when the lines are not created manually. Not a massive issue just annoying.
