Journal reason codes
Is there a setup some where to require reason codes for physical inventory journal? We want users to put in reason codes for all inventory changes.
In the Phys. Inventory Journal - you can setup different batches for different reasons.
& when you drill into Batch Name you can set default “Reasons Codes” for each batch.
They will auto populate with no user intervention needed.
If you require something different you will need a MOD.
