Journal Posting Error
Hi All
while selecting the Departmant and cost center in General journal line giving th efollowing Error:
Stack trace: The company does not exist.
(S)\Data Dictionary\Tables\Dimensions\Methods\buildSelectable - line 25
(S)\Data Dictionary\Tables\Dimensions\Methods\buildSelectableServer - line 11
(C)\Forms\DimensionsLookup\Methods\buildSelectable - line 7
(C)\Forms\DimensionsLookup\Methods\useDimSetHiearchyLookup - line 98
(C)\Forms\DimensionsLookup\Methods\run - line 47
(C)\Classes\FormDataObject\performFormLookup
(C)\Classes\FormDataObject\lookup
(C)\Classes\FormStringControl\PerformDBLookup
(C)\Classes\FormStringControl\Lookup
please help
thanks
Get a developer to debug looks like a modification impact to me
all other journals are working fine only this journal creating problem.
Can u suggest some thing that i check at my end.
thanks
Yes, check the code, get a developer to debug it. It is a stack trace error, it is not an infolog or warning.
Hi Mr.Imran,
I think you set the offset account for the JV and offset company returning empty/wrong value.
You can check returning values of the company/offset company and account/offset account from each classes.
Our client faced same problem and we found that it was due to class calling a method with empty offset company account from one lookup(dimensions) class.
Thanks & Regards
problem due the dimension only check you financial dimension related to chat of account which may effect with this journal
None of these should call a stack trace error, debugging will highlight the issue with the code, I would bet it is a development!
