Journal Description manual
Hi All ,
I have been working on AX 2012 R2 and need some clarification regarding the Journal Lines Description field.
General Journal / Payment journal / Invoice Journal - > Lines - > Description .
In the Description field user can select the existing Text code from the drop down button , but some time users need to write some text in directly in the description field.
It is throwing the error that Transaction text does not exist.
Does anybody know what is wrong?
Is this a bug or is there any other setup required?
Hope you can help.
Many thanks in advance.
You need to add the new text. To add new text right click and go to main table there make new record with Ctrl+N
Add the text which you would like to enter.
Thanks Mohammed,
If the text is repetitive users to follow the same method as said in the above post.
But some time users need to write some text in directly in the description field. So users are not interested to add the new text every time by press Ctrl+N.
Dear Mohammad,
are you using CU6 if yes then it will work. it by default.
thanks & regards.
Skype ID:- hacker_ng
Thanks Hussain for your reply.
Dear Ially,
I checked in system by default its working without error. If you still facing same error kindly send the screen shot to fix the issue.
Mohammed
SkypeID: md_itmgr
