I’m new to to this community… I need one help
How to join datasources in a form , which has no relation in table level.? I have to create a relation between purchtable and purchreqbusjustification table in form level to get value from purchreqbusjustification table…
Thanks in advance…[:)]
You can change form’s query at runtime, by adding links between the two datasources. You can use QueryBuildDataSource.addLine() method to do that, which is typically invoked from init() method of a form datasource. Search AOT form for “addLink” to get some concrete examples.
HI Martin,
Thanks a lot for ur reply…I’ll try and post the output…
Alonso
