Job Card Locked up
Somehow my job card form is locked up in new. It will not delete the header or let me put a new number in it. Is there a way to back out?
Somehow you might have a filter set against your job card. Try clicking on the show all button (the parallel bar on your your tool bar) it might help … ###### Tarek Demiati Freelance Navision Developer Email : tarek_demiati@ureach.com Phone : + 65 - 906 787 16
Or you might try and recompile the object. 1. Open object-designer, and find form 88. 2. Press F11 /Soren
Thank You, The show all button, which I did not know was the parallel bar, did nothing. When I recompile it put zero value in the job number field. I moved to the next field and exited. It is now working.
