how can i use 3 units of measurement for the same item(in all transactions) Considering that there is no fixed relation between the 3 units ? is there any way to achieve this ?
best wishes
hossam
best wishes
hossam
you have to make a relation between 3 UOM by using UNITConvert form
Nagaraj
If there is no fixed relation they are arguably three separate items
Use the Unit conversion form for the 3 types of units- Inventory unit, Sales unit and Purchase unit.
Thanks & Regards,
Parashar Banerjee.
That will not work because there is no fixed relationship as defined in the original post.
Can you explain your business requirement in detail , so that you may get the answer.
Can you explain your business requirement in detail that why you want to maintain , so that you may get the answer.
