i have made a replacement module for the navision production module since that one is REALLLY huge and the one i made is just simple and effective for the customer. now the item ledger entries i make are made with pos/neg adjustments. what id like to know is, if i can post the entries with entry type = consumption / output without getting messed up with the production thingie. and is there something i’ve gotta stay alert on?
Yes, you will have a hell a lot of problem when you run the Periodic activities–>Adjust cost. Item entries and other related periodic activities. If you are trying to channelise your new option to Negative and Positive adjmt. in Item ledger, i would not recommend you to do that. Instead create a new option type in the Item ledger and do the processing you need. Thanks Best regards Suresh NY.
