ItemId,Colour,Size,Config Wise Grouping with MULTIPLE Filters from DialogBox
Hello friends,
I m working on a report in which USER will apply a flter of multiple prodId (like ProdId1,ProdId2,ProdId3 …) from DialogBox
then ‘logic’ will do grouping of ItemId, InventColorId,InventSizeId,ConfigId based on the relation of ProdBom and InventDim…
then i will take grouped record of ItemId, InventColorId,InventSizeId,configId as a reference will fetch quantity (QTY) required to finish prodId/ProdIds applied by the user.
It is very easy with ““SINGLE”” FILTER …
here is my logic
will take 2 DataSource – ProdBom and InventDim
then group by ItemId ,colour,size,config
then i will write my code in execution section of InventDim Body
ProdBom _prodBom;
InventDim _inventDim;
Qty _qty;
_qty = 0;
while select QTY from _prodBom
join _inventDim
where _prodBom.InventDimId == _inventDim.inventDimId
&& _inventDim.InventColor == InventDim.InventColorId
&& same for size
&&same for config
&& _prodBom.prodId == Applied filter of ProdId from DialogBox
how can i achieve same thing with multiple filters of ProdId like p1,p2,p3,p4,
Help me ASAP
join
Kindly provide solution of my problem
