item without BUOM
Hi
I have item card without basic unit of measure …the enduser forgot to enter in the BUOM… they fill the UOMs but forgot to fill the BUOM
and they buy a lot as purchase and posted in kg … so the item have item ledger entries in KG …
now as we are making BOM and enter UOMKg it refuse to do it without BUOM … the item card took the Basic UOM as space …Any solution please ?
Iam thinking to enter to table by removing the validation of the UOM and then after correction return the validation ? wahat do you think …or any another solution?
Are you sure the Item Ledger Entries are in KG? They shouldn’t if KG isn’t the basic unit of measure.
if you are very sure that there is no warehouse entries, registration entries…
and all the entries were made in the base unit of measure and the base unit of measure is kg, i suppose that shouldnt be a problem.
Hi all …
Yes all the entries in kg …
But Romeo there is warehouse and thereis registeration entries entries in Kg … where kg = 1 …and in the item ledger entry the qty per unit of measure is = 1 then … it’s good that all the entries in kg …So will I do it ?
then you will have to fill it in all related tables…
