Item usage per month for in AX 2009
Hi
im having an issue to view item usage for month of August, the quantity for the item usage not getting updated. is there any settings to update this? any only there knw how to update this?
pls. advice. tq.
Tiya.
Hi Tiya,
From Which option you are taking this report?
Could you give us the path so accordingly we will suggest.
Mohammed
Hi Mohammed,
the “Item Usage” is a customized option on inventory management
Menu path: item details > inquiries > item usage
Thx…
As it is a customized option you would need to look to the customization for an answer because no one on here has the same customization [:D]
Hi Adam,
:slight_smile: found the solution for this… there was an option in periodic > calculate item usage
thx for you tym guys…[D]
