Please always mention your version of AX (ideally add appropriate tags to your questions). The answer will be very different for AX 2009 and AX 2012, for example.
i am sorry that i havent mentioned the version of AX, currently we are using Dynamics AX 2012 R2 version and we have upgrade it from Dynamics AX 2012 R version.
while uploading normal items without variants is ok but still invent module table we are not able to upload due to RecID, so we our implementation team has provided the jobs to update all items from excel.
now we are trying to upload items with variants and not getting any result.
EcoresProductMaster is getting uploaded after that which table has to uploaded we dont have information.
so if possible you can help us to solve this issue so it will be easy for our user to upload directly in the system instead of creating manually.
The Data Import Export Framework contains an entity for product variants out of the box (see Data import/export framework entities). It should be the easiest way.
The framework is there exactly for the purpose that you don’t have to understand the data model, to deal with relations over RecId etc. You would need it only if you wanted to develop a new entity, but that’s not your case. You are just a user using existing entities.
You say that the framework is too difficult for you. But do you really believe that manually reimplementing what the framework already does will be easier?
It’s really nothing difficult - you’ll import data to a flat staging table and AX will do all the difficult things in its database. You may need some changes in your data or a mapping, though, as usual when migrating data.
