Item Unit Cost
I made a mistake on posting our inventory with zero value. We had a training environment and during the process on AX training the only task that was given to me is to POST the inventory, it has Item Unit Cost in every Item then create Sales Invoice. So when we access AX Live I did the same process, unfortunately I did not noticed that all Item does not have value on it. I created our Sales Invoice for the month. Can anyone please help me fixing our concern? thank you so much for your help…
Best Regards,
Lia
What I understabd , there is no financial voucher is posted due to unit price = 0;
proceed the follow steps.
1)reverse the quantity
a. post an entry with +ve qty. so netqty becomes zero.
you may use inventory movement journal or sales credit note for this purpose.
2)Create a new sales order and mention the unit price. proceed invoicing.
Credit the invoice and then either write the stock off and back on at the correct cost or update the value through the recalculation element of the inventory close. Once the cost is correct re-raise the invoice. You could try to recalculate teh value through the close and push it through, it depends what you want and the costing method.
