Hi Guys, Can someone pls. explain the logic behind the form 6510 Item tracking lines. The source table for the form is Tracking specification,but when you open the item tracking form from Purchase Order and click assign lot no. (or make any entry)the entries are not saved in the table.But these entries are available the next time you open the same purchase Order (even if the system is restarted). How has Navision achieved this ? I have noticed a few temporary record variable of this table in the form… but do the temporary rec vars hold their values even afer system restart. I need to make a few modification in this form. Any guidence from the forum will be HUGHLY welcomed. Thax in advance.[:D][:D]
Hi, Those entries stored in Reservation Entry Table(id- 337). Kindly check the reservation entry table to find the details about item tracking line.
hi bhartiya which version of Navision are you using. Regards
quote:
Navision 3.60IN
