Item Tracking need to be Mandatory
any one can help on this issue:
my client need to Mandatory following field i.e. location, batch, serial number when creating transfer order.
In each Item card, there is a field: Item Tracking Code.
Assign a code here, that has the needed setup.
For each Item Tracking Code You can define on which documents Batch/Serial number is needed (inbound/outbound transactions).
For Mandatory location - in inventory setup there is a checkmarks - “Location Mandatory”. If this is marked, then for all transactions location will be needed.
Doubt You would need mandatory location only for transfer orders, and for other transactions it would not be mandatory.
Kaspars
This requires customisation.
Jordi
