As a solution centre, we are experiencing problems with implementing systems with Item Tracking functionality in 3.60 (specifically relating to integration with Reservations, Warehouse Management and Manufacturing). The item tracking functionality in 3.10 was completely rewritten in 3.60 and it appears as though it is still not quite right. Is anyone else experiencing simalar problems? Is anyone aware of any amendments to this functionality in 3.70? I know that 3.70 consists mainly of bug fixes, but do not have any details of what these fixes relate to…
If you look at the code in form 6510 … slightly overengineered ? - The blocked flag on the SN/Lot N° information card no longer prevents a user to sell the product. It does seem to work when you set the Lot No Info Must Exist flag. - Conflict make 2 purchase order receipts : LOT1, LOT2 this results in 2 Item Ledger Entries : 1 and 2. make a sales order, item tracking and select LOT1. assign Item Ledger Entry 2 (which is LOT2) to the sales line : via the field Appl.-to Item Entry => you can post without any issue : you get a posted tracking of LOT1, and when you look at the ILE, the remaining quantity of Item Ledger Entry 2 is now one less … I would have guessed that we would get an error on post of the shipment saying we have provided conflicting information. - The Systems looses the order tracking when changing the vendor No. Take Item No. LSE-8 Vendor No. 60000 (in the Item Card) Vendor No. 61000 (in Item Vendor Catalog) Let the field “Lead Time Calculation” empty. Now make an Sales - Order for 20 pieces, Location Code Blau and calculate the plan in the Requisition Worksheet. Try the order tracking for the received line and you will get the right connection to you order. Now change the Vendor No. in the Requisition Worksheet to 61000: the Due Date is empty and the order tracking is lost. - When you ship a Sales Order with a Lotted Item in a non-base unit of measure, the invoice can’t be created due to rounding on the Item Tracking Entries. - … The service request system is full of item tracking related issues. However there are already 14 (!) hotfixes out there, which should help a lot…
Hi, We are encountering similiar problems with ordertracing, do you know by hard which Hotfixes for 3.60 are out there, regarding Order Tracking. /Sven
quote:
There are > 10 fixes for W1 (don’t know if they al relate to tracking). The best fix is probably 3.70 [:D]
I have implmented full lot control at a client and experienced numerous problems. Basically the response from Navision is to upgrade to 3.7 Rounding on sales and purchaser orders as mentioned above. Stray reservation entries preventing output journal posts. Issues with undo shipment/receive and lot controled item. Reservation entries not carried to lots… There is more.
