Hi all, I wanted to know whether the hight, Length and width and weight parameters given with the units of measure table are usable witrh item tracking or not. I mean can we govre different values to these attributes for each serial number or lot number? IS the serial/Lot number information field usable with this? In my case, The employee needs to select the item to be picked on the basis of one of these parameters. Has any body tried this? Regards, DD
Hi, As per the standard features available, one you can assign variant to Item tracking number(SL/Lot). However, any other parameters/details can be assigned in the form of comments. If one wants to assign different dimensions(Width,Length and Weight), same can be assigned as comments and as such no validations are possible. Regards. Kashinath.
