Item table is taking too much time to open (Item list page)
Can any one tell me how to increase the Performance of the Item list page (Item Table)? I have 34,000 Rec in my item table. I tried to see if I have any bad index but to be honest I rebuild most of them hoping that this may increase the performance. But its still slow.
Any Idea? :slight_smile:
Do you have any flowfields in list page?Please remove them and try.
Read this: http://dynamicsuser.net/forums/p/83039/458005.aspx#458005
People LOVE to overload Item List with FlowFields (i.e. calculated and/or lookup fields) to “quickly” see availability by different locations etc.etc.
Thanks all for the reply.
I have almost 200 columns in my item table and almost 20 flow fields. any better approach to keep those flow fields?
If you have NAV 2013 or later version, check out this link: https://msdn.microsoft.com/en-us/library/hh165526%28v=nav.70%29.aspx
and this (3 years old, for ver 2013 - later versions solve some of issues Mark highlights in this article) http://nav-skills.com/2013/09/10/tip-35-using-queries-in-pages-reports/
It’s not an exact solution of your issue, but gives an idea how to make use of new NAV features.
Hi Ivans,
Thanks. Your solution looks nice!
But the only problem is that when I create query I canot have a flow field in it? Right?
you could replace some of the flowfields by normal fields with a code value and filling them by code at runtime in e.g. the onaftergerrecord trigger.
