Is there any way to get alert or message if there is not enough qyt in inventory when I post sales journal to transfer to sales order in AX 2009?
Thank you,
Taka
Thank you,
Taka
You are changing the status from journal to order? Do you have reservations activated?
I post journals from Periodic and activated reservation.
Thank you,
Taka
No I do not believe you can as standard, the periodic job changes the header status to sales order without refreshing the lines and calling the reservation code. I would need to set it up, but I presume you have reservations on and it is not telling you so therefore it does not do it.
