Item Reclass posting error
hi all,
i am doing a massive (>5k records) transfer of stocks from 1 location to another, 1 bin code to another using item re-class.
but when i tried to post them got an error: item specification exists.
firstlt i export all the stocks in my ILE with remaining qty>0 out to csv file, then i re-import them into a re-class journal.
the importing into item journal was good, until i tried to post the reclass journal got item tracking issues.
it seems some item are set with item tracking code, and they are associate with some sales documents (eg: sales quote, sales line, blanket orders) already.
how do i modified the item tracking specification thingy?
Check on Item card whether Item tracking is enabled.
If yes while reclassification check you have attached serial no.
hi amol,
Check on Item card whether Item tracking is enabled. YES its enabled with item tracking
If yes while reclassification check you have attached serial no. YES i have import them with lot number into my reclass journal as well.
ACTUAL ERROR MESSAGE:
Lot number is required for item 12345.
When I do debugging, it goes to CU22, SplitJnlLine,
IF NOT ItemJnlLine2.Correction THEN // Undo quantity posting.
ERROR(Text011);
