Hi
Can anyone advise on the following
We often need to provide costings of qty’s breaks for the same item.
example
finished item cost for qty of 10/50/100
Now we all know that the more you buy the cheaper the finsihed item. but the problem i see is having to change the cost of the component part line in the sim prod order. This is all well if the component lines are about 5 lines but when there is a list of 30 compoents on each sim prod order there is a lot of changing to be done.
so at the moment the procedure is as follows as i understand it to be
i need to cost for quantity of 10/50/100
raise 1 sim prod order for qty 10>edit cost on each individual component lines (30 components)
raise 2nd sim prod order for qty 50> again edit cost on each individual component lines
raise 3rd sim prod order for qty 100 > same as above
as you can see there is quite a bit of work here. I have tried to work out if i could use the sale prices and purchase prices but they only apply to sales and purchase orders as expected!
Any advice on how i could reduce my work load would be great.
thanks
