Hi all
I need to have report lists purchases per item with full details :
posting date - vendor code and name - QTY. - unit cost - and value
is there any similar report??
thanks in advance for all
Hi all
You can look at standard report Vendor/tem Purchases or Inventory - Vendor Purchases
Or you can design report from Value entry or item ledger entry.
Dear Amol,
thanks a lot for you kind reply ,
[:D]
Theses reports solves a part of my problem ., but I need to list all purchase invoices related to a certain item from all vendors .
Welcome
For list of all purchase invoices for single item
Go to Item Card–> Click on Item button–>Click on Entries–> Select Value Entries–> You will see all the entries related to that item
Filter on Item Ledger Entry type field as Purchase.
You will get your desire output.
thanks [:D]
Welcome[:)]
Dear Amol
I have more two questions: [:)]
1- how can I enter a purchase invoice in a currency other than LCY??
2- how to print a posted " item ledger entry"??
In Purchase Invoice screen select desire currency code in Foreign Trade tab
What do you mean by print posted item ledger entry. ? What is require to print ?
we use item journal to adjust inventory manually.
sometimes we need to re-print a posted item journal entry
thanks again and again
You can look at the Warehouse–> History–> Registers–> Item Registers
Here you can have all the entries
Just click on entry you required–> click on Register–> select Item ledger
I really did this , but how can I print the entry??
