Item output entry revaluation???
Hi, all For some reasons client needs to revaluate manufacturing output entry. I tried use manually revaluation journal, but receive error “You cannot revalue outputs manually”. But if I try to use function “Calculate inventory value”, then I get this output entry and can revaluate to value I want. What is reason to forbid enter lines manually?? Is this bug?? Regards
Found in partnerguide DK-979-898-BHYW. It’s bug from version 3.01. Strange it’s not corrected until version 3.70a. Thanks
