I believe product builder is your only real option at this level of configuration. You basically get to chose the DDR, then make, then model, this would all relate down to an item, but you would need to put this into product builder as a configured item with all of the rule sets and choices I believe.
Unfortunately Adam, We have Puchased atmost every license… but we didn’t go for Production builder.
and also How Product builder helps us in Item Master…because as far as i know product builder is good with Enterprise portal. isn’t it ?
Nope Product Builder has nothing to do with Enterprise Portal. It allows you at the sales entry point, against ONE item record to ask a series of questions, what make, what model, what RAM etc and givien these answers it will build you an item specific BOM for the answer to the questions. Ultimately it is a configurator. I believe to achieve what you need without creating thousands of item numbers for each configuration then you would need this, at least to assess it and decide - bit unsure how you could have got through presales and not bought it if it is critical to the business.
We have Our Own Develpoer who have Created Whole ERP with KPI/KRA, Dashboard, Balance Card Etc over Periods of 10 Years. but they are not able to build MRP, Schedule Planning, Etc.
so we have decided to use Standard Product as the developer needs to develope and Maintain so many things in a day to run Inhouse made ERP Precisely and Correctly… and If Data Mismatch…they just go to Database and Adjust what ever needed…I hope You got what it is ?
I Just Recently Joint and Working as Project Leader to Implement Axapta 2009 and I have always work with Manufacturing Company.this is My First I T company…
Thanking You.
