Item Ledger remaining quantity
We have a situation where the quantitiy field total does not equal the remaining quantity total. Anyone have any ideas on how to fix? It is kind of tricky becuase remaining quantities can be on several lines. Thanks
Hi do you mean that for the same item the sum of Quantity of its ledger entries is different from the sum of Remaining Qty? In my experience this happens only when someone delete or modify manually item ledger entries.[V] If this is the case, you should adjust manually the entries … but it could be complicate to do it.[xx(] To have an idea about your case, you could check if there are missing Entry No. in ILE, also you could recalculate the remaining qty of each item entry using Item Application Entry table 339 (if people who does the modification forgot to adjust the applications).
