Item Ledger Entry Document Type
Hello,
Can you explain what process will set the Item Ledger Entry Document Type to Purchase Invoice ?.
Andrew
That will happened if in “Purchase & Payable Setup” Receipt on Invoice is False (Default value is TRUE), and then you POST a Purchase Invoice (note, it should be Purchase Invoice, rather than Purchase Order)…
